LNK306 - Expecting 5.0V output... getting 10.4V output instead
Discussion in 'General Electronics Chat' started by Mahonroy, Mar 24, 2016.
Thread Status:
Not open for further replies.
  1. Mahonroy
    Oct 21, 2014
    200
    5
    Hey guys,
    I used the LNK306 to create a 5.0V rail on my PCB. (120VAC input). I used the datasheet to come up with the component values.
    The problem is that I am getting a 10.4V output instead of the desired 5.0V. I double checked the feedback resistors, and they are 2K and 3.84K which should generate the desired 5.0V output.
    Has anyone had any experience with these line of IC's? I attached my circuit schematic, and the PCB layout of the circuit. Any help would be greatly appreciated as I am at a loss as to what might be wrong, or how to go about finding the problem, thanks!
    Here are the part #'s I am using for the Inductors, Diodes, and Capacitors:
    D1, D3: DFLU1400-7
    D2: US1JHE3/61T
    D4: FM4007W-W
    L1, L2: 46105C
    C4: GRM219R61E106KA12D
    C6, C7: 475CKE450MLN
    C8: 35ZLH100MEFC6.3X11
    R3: WP2S-7R5JA25
  2. ResFiber
    Mar 9, 2016
    5
  3. Mahonroy
    Oct 21, 2014
    200
    5
    I already have a topic posted there as well ;-)
    They have terrible customer service though so I wasn't holding my breath. I figured it would be more worth while to see about getting advice here instead.
  4. Dodgydave
    Jun 22, 2012
    5,143
    768
    Can only suggest altering the resistors feeding the fb pin, to see if it changes the voltage, never worked with this chip.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Did you read the User Agreement ?
    In point 6 the restricted topics are mentioned.
    Transformerless powersupplies is one of them.
    Bertus
Thread Status:
