LMB204BFC 20x4 LCD problem
Discussion in 'Embedded Systems and Microcontrollers' started by walid el masry, Feb 10, 2012.
  1. walid el masry
    Thread Starter Active Member
    Mar 31, 2009
    132
    i have LMB204BFC 20x4 LCD since long time ago and i can't remember if i break it mistakenly but when i tried to use it again i noticed that 1st 8 characters of rows 1&2 is not working properly and i don't know why, so i hope anyone can help me !!!
    a description to my problem is in this video
  2. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Check your contrast pin. Do you have a resistor or better a potentiometer on contrast?
    Check you initialization code. Do you know it has worked before?
    Step through your code, use a scope or logic probe and verify commands and data are getting to the LCD the way you think they are getting there.
  3. walid el masry
    Mar 31, 2009
    132
    everything about the hardware and software is ok, it not the 1st time i use LCD but its just weird that i lost the 1st 8 characters when i reach the 3rd row it just annoying they work way and not in another so i hope if the is explanation to this and if it is an internal hardware defect
  4. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Well if everything is OK then why is it not working? Obviously you have a problem somewhere. You also could simply have a bad LCD.
    And could you please use capital letters to start a sentence and a period to end one? Otherwise it is really annoying to read.
  5. walid el masry
    Mar 31, 2009
    132
    Well, am sorry if i annoyed you!.
  6. spinnaker
    Oct 29, 2009
    5,102
    1,190
    I didn't say you annoyed me, I was just pointing out that it is only common courtesy to make your posts as readable as possible.
  7. walid el masry
    Mar 31, 2009
    132
    Ok thanks, i will buy another one they cost about 10$ here, i just wanted to know if there are any explanation to this but sounds like its a hardware defect due to something i didn't noticed.
    Thanks again.
  8. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Yeah I have blown out about a half dozen of them and have seen similar
    behavior.
    The white boxes are usually a hint of contrast problems but the strange jumping around like that usually means a bad device assuming everything else is OK.
    The video was a good idea.
    I like to try and put headers on all of my LCDs. Make them all the same for each project. So what I did was to build an LCD tester. I can simply plug
    in an LCD and test it if I suspect it is bad.
    You are living in Egypt now? Is it still easy to get product with all that is going on? $10 US is a pretty decent deal if it is a local purchase.
    I can't do that well here if you throw in shipping. I don't know of anywhere within several hours drive that might carry anything like that. Pretty sad as we used to have at least two electronic distributors in the city along with one other that sold surplus gear. They are long gone.
  9. walid el masry
    Mar 31, 2009
    132
    Yes am from Egypt, what is going has nothing to do with buying something tho and it not that critical.
    It's a supplier in Cairo called Ram Electronics, i will send you their link in private if you would like to check them, they are like Radioshack in US.
    They are about 90 min driving from my city however i still can get them here from local small shops in case they didn't run out.
