LM833 preamp design
Discussion in 'The Projects Forum' started by ali8tor, Apr 2, 2013.
  1. ali8tor
    May 29, 2012
    43
    Hi
    I have a project Im working on and I'm a bit stuck, I need to consider to design a preamp using an LM833?
    thanks guys
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    What is your question about using an LM833? What are your requirements?
  3. ali8tor
    May 29, 2012
    43
    Hi
    there are no major specifications, it only need to take in a Mic signal and amplify it.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    ali8tor likes this.
  5. ali8tor
    May 29, 2012
    43
    hi im still abit confused about the resistor/ capacitor values and how do i figure out the filter order?
  6. #12
    Nov 30, 2010
    16,704
    7,351
    Use the "zoom" or magnification feature of your PDF reader to see the resistor and capacitor values. The high pass filter is first order, the low pass filter is second order.
  7. ali8tor
    May 29, 2012
    43
    okay i got that thanks, how much gain would you recommend using for the Lm833 preamp?
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Interesting chip. What made you decide to use it?
    I have a similar project in progress using a different op amp. I'm making mine variable gain. When I have a gain value I will try to post it here.
    ali8tor likes this.
  9. #12
    Nov 30, 2010
    16,704
    7,351
    The gain that is in the circuit provided.
    You see, without knowing what kind of microphone or what your final output goals are, we can't guess how much gain. Apparently you can't either. Just build the obvious one and if it sucks, at least we have a starting point.
    "Interesting chip"
    Yeah. They are so old that mold has grown on the ones I have.
    ali8tor likes this.
  10. ali8tor
    May 29, 2012
    43
    Im just experimenting with this LM833 and I heard its a decent chip guess I'll find out soon, awesome look forward to seeing it!
