LM7805 Making Cellphone shut down
Discussion in 'General Electronics Chat' started by imzack, Apr 18, 2012.
  1. imzack
    Thread Starter Active Member
    Nov 3, 2010
    50
    Ok, im trying to make a cellphone charger from a batterypack, i have 7.2 volts going into my lm7805, I wired it up correclty i believe. I think attach the Vout and the ground to my cellphone wires, i hook the cellphone cable to my phone.
    Once i do this, the cellphone turns off and the LM7805 got SUPER hot, i unplugged it, assuming its getting too much current for some reason.
    Does anyone have any idea why this is happening?
    Any suggestions?
    Zack
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    Would be nice with a schematic. Are you using a car charger?
  3. imzack
    Nov 3, 2010
    50
    no, I have 18, 1.5 volt cells. 3 strands of 6. so 6 batteries in series giving me 7.2 volts and three of these in parallel.
    ill see about a schimatic
  4. imzack
    Nov 3, 2010
    50
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    Do you have the heat sink?
    What are the values on the caps?
    You sure you haven't turned the IC the wrong way?
  6. imzack
    Nov 3, 2010
    50
    .33 micro farads electrolitic cap, and a .1 micro ceramic(on the out end)
    um no heat sink, it turn the phone off immediatly though
    and the ic ive double checked.... looks good to me...
  7. nerdegutta
    Dec 15, 2009
    2,565
    805
    Have to ask, but have you checked for shorts, solderblobs and stuff like that. I suspect there is a short somewhere. How's the cable you connect to the phone?
  8. imzack
    Nov 3, 2010
    50
    solderblobs?> what is this and how does it affect the circuit?
  9. nerdegutta
    Dec 15, 2009
    2,565
    805
  10. tracecom
    Apr 16, 2010
    3,878
    1,396
    Here's a quote from the description of the circuit in your link. "This resistor does a very important function of current limiting and restricts the flow of excess current into the phone."
