LM741 Single OpAmp schematics?
Discussion in 'The Projects Forum' started by zombiepokla, May 15, 2009.
  1. zombiepokla
    Mar 30, 2009
    12
    anyone know any relatively simple schematics that use one or more LM741 op amps? I'm just getting started in electronics, and I was wondering if anyone could help me find some schematics for audio applications using LM741 IC's. Thanks!!!
  2. PRS
    Aug 24, 2008
    989
    35
    Are you familiar with the standard op amp configurations?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    A 741 opamp is too old (it is 41 years old) and has spec's that are no good for audio.
    The high frequency response fails above only 9kHz and it is too noisy (hissss).
    There are much better audio opamps that cost the same today. They are also available as a dual or a quad opamp.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Most op amps use the 741 pinout. The 741 is a very poorly-performing op amp by modern standards, but works acceptably in low frequency applications.
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    Texas Instruments has a tutorial about everything about opamps:
