LM741 Pre Amplifier help: How to remove such a huge amount of noise at the output ???
Discussion in 'General Electronics Chat' started by HaseebEngineer, Aug 9, 2013.
  1. HaseebEngineer
    Aug 8, 2013
    22
    Here is the schematic of what i made so far ... I have an 8ohm speaker .. the output of this amplifier is not that much loud but too much noisy ... I have used several decoupling and bypass capacitor but that didn't work for me :(, instead of making it better it completely remove the sound ... Please help me for how to get a clear sound at the output ... or tell me whats wrong with this circuit ... Thanks alot ... Em Haseeb Khan doing Electrical Engineering ...
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  3. GopherT
    Nov 23, 2012
    6,303
    4,021
    A modern general purpose op amp is supposed to have 600 or more ohms as the load. Your circuit has only 8 ohms. You will get noise and saturation with that.
    Remember, a power amp supplies low resistance loads. A pre-amp amplifies things like microphone or guitar signals to a line level (about 1 volt rms) and passes that to a power amp.
    You have a pre amp circuit.
    Your circuit has a gain of 100x - depending on the power supply, you may be getting saturation if your input signal is too big (more than 0.20 volts peak-to-peak with a 24 volt supply).
    Also, the ressitors to your virtual ground for your non-inverting input may be a bit too big. You will get less noise with 10k resistors to Vcc and non-inverting input, then another 10k for non-inverting input to ground. A jfet input op amp like suggested above can handle higher value resistors there (100k).
    Finally, I would put the output capacitor after the potentiometer - not before as shown here. The whole feedback loop is floating in your schematic and that can cause some latch-up issues. Put a 1k resistor in series with the potentiometer between the op amp output and the potentiometer) to insure you have at least 1k ohm resistance when volume is all the way up.
    PackratKing likes this.
  4. BobTPH
    Jun 5, 2013
    806
    121
    If you want to power a speaker, use an LM386, which is designed to do just that.
    Bob
  5. HaseebEngineer
    Aug 8, 2013
    22
    Thank you guys for help :)
  6. HaseebEngineer
    Aug 8, 2013
    22
    I have a 11v and 1A transformer ... I have made a negative supply using NE555 IC ... so now my positive and negative terminals gives about +-15 volts ... I have set the amplifier to give an output of -9 volts ... the input is i guess 0.336 volts ...
  7. HaseebEngineer
    Aug 8, 2013
    22
    What about this circuit ... I have an input of 0.336v and output gives me -7v all the way up ... but with a lot of noise ... can anyone modify this for me to have almost no noise ... please help
  8. HaseebEngineer
    Aug 8, 2013
    22
    or can i use two or three amplifier in series to minimize the noise ? but how ?
  9. GopherT
    Nov 23, 2012
    6,303
    4,021
    Do you have a real circuit on a breadboard or just this simulation?
  10. JoeJester
    Apr 26, 2005
    3,393
    1,211
    What are your design specifications? What is the preferred input signal specificatoins? What is the output load?
  11. HaseebEngineer
    Aug 8, 2013
    22
    Yes ofcourse i have a real circuit ..
  12. HaseebEngineer
    Aug 8, 2013
    22
    Input is a simple audio jack out of a laptop which is normally 0.3volts peak to peak ... and output is connected to an 8ohm speaker ...
  13. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    As said before, you can NOT drive an 8 Ohm speaker with a LM741.
    You will need an LM386 or better to drive an 8 Ohm speaker.
    Bertus
  14. HaseebEngineer
    Aug 8, 2013
    22
    Okay thanks for the help .. I'll go buy LM386 tomorrow ... if something went wrong i'll contact you ... can u suggest some best audio amplifiers for i can make a subwoofer system as well ... ?
  15. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  16. HaseebEngineer
    Aug 8, 2013
    22
    I have studied about the amplifiers but i just dont know which IC to use to have a perfect and the best loud amplifier ??? I want to make a subwoofer along with left and right speakers ... a loud one without any noise ... can u suggest me a circuit or an IC ? high wattage high voltage with almost no noise ?? ...
  17. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    How much power do you want for the left and right channels?
    How much power do you want for the sub-woofer channel?
    You also will probably need a sound processor for the sub-woofer.
    All circuits for these can be found on the projects page of Elliots Sound Products:
    http://sound.westhost.com/projects-0.htm
    Bertus
  18. HaseebEngineer
    Aug 8, 2013
    22
    I want both left and right to be 60W .. and the subwoofer to be minimun of 6W ... which IC should i use ?
  19. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    The LM3876 will give you an 50 Watt output.
    Have a look at this project from the page I gave you:
    http://sound.westhost.com/project19.htm
    I am not a sound expert, but as far as I know the sub-woofer amplifiers are bigger as the left and right channels.
    Bertus
  20. HaseebEngineer
    Aug 8, 2013
    22
    I have b0ught TDA2030A Amplifier ... So now how can i make a subwoofer with it ?
