That is the easiest option. You might also want to look if the coupling cap is a good idea or not. I think it needs to be a DC input (no coupling cap).Yeah I saw that I just wanted to make sure. It kind of makes sense why my circuit is not working. Whats happening is I am feeding a square wave oscillator into pin 3 of LM567 with a coupling cap also. On pin 8 on the output its a square wave. The way I setup the component is so that when It detects a certain frequency in my case 150 kHz, the output will sink to Grd. Yes I do have a Pull up resistor on the output. I guess I will use a voltage divider to get that voltage down in the mV range.
by Don Wilcher
by Jake Hertz
by Jake Hertz
by Aaron Carman
