LM567: a good start, some issues
Discussion in 'The Projects Forum' started by mxabeles, Jun 14, 2013.
  1. mxabeles
    Thread Starter Active Member
    Apr 25, 2009
    182
    Hi There,
    Started work anew with LM567s. Got them to respond to frequencies coming out of my computer, which is a good start. Hooked up using the headphone jack.
    The timing capacitor is 0.022 uf, and they are set to respond to 11.7kHz, 8kHz, and 7.5kHz. The problem currently is they only work being fed a single tone.
    For this project, using multiple control frequencies at a time is key. Tried playing with amplitude, thinking distortion might have been the culprit. No luck there...Any suggestions?
    Thanks,
    -M
  2. mxabeles
    Apr 25, 2009
    182
    some more wiring info:
    Splitting the control track from my computer,
    I simply have my 1/8th mono cable going to 10uf cap. From the cap, it is just jumper cabled out to the input of each LM567. Maybe a better way to split the signal?
    Thanks again,
    -M
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Have a look at page 8 of the attached datasheet to set the bandwidth.
    Bertus
  4. mxabeles
    Apr 25, 2009
    182
    Hi Bertus,
    OK, I'm trying to figure this pdf out. In layman's terms, messing around with C2 might do the trick, yes? Seems that sets the bandwidth.
    Best,
    -M
