LM565 Project 80 MHz
Discussion in 'General Electronics Chat' started by tonci, Sep 14, 2016.
  1. tonci
    Sep 14, 2016
    6
    I am working on project which contains LM 565 Phase Locked Loop. I have a question about simulating LM 565. Can some one tell me where can I find simulating block LM 565. Can someone suggest me any simulating program. I work with multisim 10 and there is no LM 565 in any library.
    Thank You for answer!
    Tonci
  2. tonci
    Sep 14, 2016
    6
    Here is electrical scheme of Phase Shifter working on 80 MHz phaseshift.jpg phaseshift.jpg phaseshift.jpg
  3. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    How do you expect an IC with specs of typical 500 kHz to work on 80 Mhz?
    Bertus
  4. ci139
    Member
    Jul 11, 2016
    341
    39
  5. R!f@@
    Apr 2, 2009
    8,791
    771
    A 500KHz max VCO at 80MHz....?? o_O
  6. Alec_t
    Sep 17, 2013
    5,977
    1,136
    The OP07 opamp has a closed loop bandwidth of only 0.6MHz :(.
    The LM311 has a typical response time of 200nS :(.
    Neither of these IC's would be suitable for 80MHz working either.
  7. hp1729
    Nov 23, 2015
    2,100
    233
    The signal going to the OP07 and LM311 is not the VCO output, is it? But yes, 500 KHz is the top frequency of the LM565.
    Given R1 and C1 values in the schematic it looks more in the neighborhood of 100 KHz. Adjustable to 80 KHz? Not MHz. Was that what the OP intended?
    absf likes this.
  8. Threeneurons
    Jul 12, 2016
    19
    10
    As the others have mentioned, the ICs shown, can't handle that high of a frequency.
    Is 80MHz a typo ? Why 80MHz ?
    What are you trying to achieve ?
  9. GopherT
    Nov 23, 2012
    6,319
    4,043
    Hey, if he wants 80MHz out of a 0.5MHz chip, it should be possible - it just takes practice and hard work. Focus and stop being so negative, People!
  10. R!f@@
    Apr 2, 2009
    8,791
    771
    Can I make my 4GHz PC to 40GHz if I keep at it ?
  11. GopherT
    Nov 23, 2012
    6,319
    4,043
    Yes, you can! Stay positive and keep trying. You can't become a world class athlete without practice.
    Sinus23, absf and R!f@@ like this.
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I guess we can all retire rich! I'm in -- sign me up.
    Sinus23, absf, R!f@@ and 1 other person like this.
  13. R!f@@
    Apr 2, 2009
    8,791
    771
    Hey ..I am already rich with enthusiasm. :D
    GopherT likes this.
  14. GopherT
    Nov 23, 2012
    6,319
    4,043
    Then you'll achieve 40 GHz in no time.
