lm4991+problem
Discussion in 'The Projects Forum' started by ekremhb, Nov 9, 2009.
  1. ekremhb
    Nov 9, 2009
    I want make my mp4 player 3w sound amlifier whit
    lm4991 and design my circut base of own pdf but I have not listen
    any sound from speaker or not any sound what is the problem
    Can you help me
    supply voltage 3,7 lion cell speaker 8 ohm 3w
    Regards
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    From page 2 of National Semiconductor's datasheet:
    Did you build your circuit according to that schematic?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet for the LM4991 shows that it works when its supply is as low as 3.7V but its output power into 8 ohms is low. It is only 0.7W at 1% clipping distortion which will be audible. Its output power at clipping (low distortion) is only 0.58W which is less power than a cheap clock radio. Its power output will be less as the battery charge becomes less than 3.7V.
  5. ekremhb
    Nov 9, 2009
    Yes I am build same circuit
    and pin 1 is tied to gnd for lm4991 to on state
