LM393A Comparator Issue
Discussion in 'The Projects Forum' started by dbirky, May 24, 2016.
  1. dbirky
    Jan 21, 2011
    No matter how I wire this I keep getting 0VDC at pin 1. I am needing it to be 5v. This drawing was how I wired it last time. I have pin 4 at ground and pin 8 at +5V. The sketch shows how I was testing it. What I really need is to have pin2 at 0v and have pin 3 connected to a speaker lead from a radio. When there is audio on the pin 3 I need pin 1 to be 5V. Also when I had pin 2 at GND I had a + speaker lead on pin 3. Then I played a tone on pin 3 and was hoping pin 1 would go to 5V. It remained at 0. Any help would be appreciated.
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    You made a common omission in using these comparators.
    The output of that comparator is an open collector transistor so you need to add a pull-up resistor from the output to the +5V (or other positive voltage), so the output can go to a plus voltage when the (+) input exceeds the (-) input voltage.
  3. GopherT
    Nov 23, 2012
    6,309
    4,029
    Just to add onto @crutschow 's post. I attached the schematic of the guts of the LM393 below. Look how the transistor is connected to the output pin. There is no connection to Vcc (positive power). Most comparitors require the user to add this resistor for their application.
  4. dbirky
    Jan 21, 2011
    Thanks for the response. Doesn't putting a resistor from Vout to Vcc put 5V to Vout whether or not the + input exceeds the - input?
  5. GopherT
    Nov 23, 2012
    6,309
    4,029
    No, that is the whole point of a transistor. When no current is flowing through the transistor, both ends of the resistor are at the same voltage (Vcc). When the current flows into he base of the transistor, the Emitter-Collector path becomes conductive and current can flow. The voltage across the resistor becomes Vcc minus about 0.2V (the voltage drop of a staturated transistor (Vce)). So, the output is LOW when the transistor conducts and High when the transistor does not conduct current.
  6. dbirky
    Jan 21, 2011
    Sorry for being thick. I've set the circuit up on a breadboard but get 5V on Vout anytime the pull-up resistor is connected. Here is the schematic:
    would this be correct?
    Thanks again!
  7. crutschow
    Mar 14, 2008
    13,496
    3,373
    Due to the input offset voltage of the comparator you may need a few mV less than 0V to cause zero at the output ( or add a few plus mV to the (-) input .
  8. wayneh
    Sep 9, 2010
    12,382
    3,239
    Yes, comparator can be unpredictable right at the power rail. It's better to set a specific reference voltage - not at either of the power rails - to give the output switch at the Vin voltage you need.
