Oh, I see the crossed inputs for the two comparators now. Yes, the behavior is correct. Why do you need to simulate it?when i set R2 pot more than 4.5V, the LED that just now off will be on and the other LED will be off.
just one LED will be on at a time.
the scenario u presented seems like u want to test the voltages in sequence which according to my knowledge can only be done while cascading opampshurm. no.
actually i want to design a circuit which can compare voltage.
4 voltage.
V1 , V2 , V3 , V4
V1 is on , V2 is off.
when V1 less than V2 , V1 will off and V2 will on.
V2 on, V3 off.
then V2 will compare with V3.
when V2 less than V3 , V2 will off and V3 will on.
V3 on , V4 off.
V3 less than V4 , V3 off V4 on.
by using LM393 ,
the VR1 less than VR2 , LED 1 will off and LED2 on.
now i want to continue it for V3 and V4.
is it possible by connect the output of circuit A to the input of circuit B?
by Jake Hertz
by Duane Benson
by Don Wilcher
