LM393 comparator schematic?
Discussion in 'General Electronics Chat' started by norman, Dec 12, 2005.
  1. norman
    Dec 12, 2005
    Hello forum members,
    I have to interface a shaft enocder with uC, but due to some reason the uC is not counting the exact pulses of encoder. I now want to use comparator to reduce noise and define the encoder signal. I have LM393 with me but unfortunately don't know how this could be used to achieve what I am trying to do, could someone please suggest a simple schematic for LM393, I mean which pins are used for what purpose (how connections are made on LM393?) or how encoder pulses be connected to comparator?
    I would really appreciate your time and thoughts on this
    Regards
    Norman
  2. dougp01
    Member
    Dec 6, 2005
    27
    Go to this link: http://cache.national.com/ds/LM/LM193.pdf and you will find the National Semiconductor data sheet.
    Without any idea of what your noise profile is, I suggest you add a little hysteresis to you circuit to eliminate noise. Maybe start with about 50% over the range of voltages you are interested in detecting.
    -Doug
  3. Sebi
    Sep 24, 2005
    59
    I mean, for this purpose quite enough a schmitt-trigger, like CD40106 (74C14).
    If You choose the LM393, don't forget the pull-up resistor for output (open collector).
