Hi all and thanks for your attention...
I tried everything before posting and i couldn't come to any solution for the problem, so i beg you to give me an hand.
I'm trying to realize a circuit that lights up a LED (orange 3mm) when battery voltage is below the 3.4v threeshold. I would like to use the circuit inside of another project where my 4.2v li-ion battery is connected to a boost module in order to obtain 6.2v (to power up a small amplifier).
I used the module output (6.2v) to obtain a reference voltage through a voltage divider (10k-12k -> 3,37v) and i fed this reference v to the inverting input.
I connected the + battery to the non inverting input.
I'm powering the LM393 directly from the battery (4v~3v).
All i can get is an always ON led (even using a pullup resistor between output and VCC pin... I tried both 1k and 10k values...). I'm loosing any hope and my brain ... Please help me. Thanks in advance!
PS. Right now i don't have a schematic for the circuit i'm using since i'm only trying it on a perfboard (without the amplifier to make things easier) but it's just like i described it above
