LM3915/LM741 amplifier
Discussion in 'General Electronics Chat' started by AR_BO1021, Jun 17, 2016.
  1. AR_BO1021
    Nov 28, 2015
    Hi
    I have built a vu meter with the LM3915 IC and i want to amplify my audio signal because its to low from my mp3 which is 300mV.
    To how much should i amplify the voltage and why?
    Is lm741 a good amplifier to use?
    Is there any difference between using ±12v or 0v and 24v to supply the lm741 amplifier?
    Thanks,
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    Hi
    First, what did you set the reference voltage to? Now is a good time to post a schematic.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Probably not a good choice for your application.
    Yes. LM741 is spec'ed to have a common mode input range to about 3V from the rails. If you use a single supply, the input couldn't go below around 3V. With dual supplies, oV would be supported. If you don't already have a negative supply, I'd use something else.
    As mentioned, you should post a schematic so we don't have to guess about your circuit.
  4. AR_BO1021
    Nov 28, 2015
    Vref is set to 10v
  5. benta
    Member
    Dec 7, 2015
    101
    24
    1: no need to amplify anything, just insert a voltage divider between REF-OUT and R-HI.
    2: The LM741 is NOT a good amp to use in ANY situation. Send it to its grave and RIP.
    3: not relevant.
    Benta.
  6. dl324
    Mar 30, 2015
    3,377
    651
    It will work fine for many applications. I have dozens in my parts bins and find them still quite useful.
  7. Lestraveled
    May 19, 2014
    1,957
    1,218
    You don't need an amplifier. Just change your reference to 1.2 volts.
