LM3915 Flickering Issue
Discussion in 'The Projects Forum' started by BuxZED, Aug 25, 2014.
  1. BuxZED
    Apr 14, 2014
    32
    Attached is a circuit I created to display the intensity of vibration of a machine using a output of a piazzo device
    although the circuit works fine, you can notice some flicker in the LEDs and brightness variations.
    I prepared the below peak detector hoping that would sort the issue but with no luck.
    dose any one have simpler peak detector that i can use with this, ideally a one that would work with 3.6V?
  2. MrCarlos
    Jan 2, 2010
    400
    134
