LM3914 resistor values for 4.2V to 3V Li-Ion battery
Discussion in 'The Projects Forum' started by gauravkothari23, Nov 13, 2015.
  1. gauravkothari23
    Nov 13, 2015
    14
    Mod edit:
    Please don't hijack the other member's post, now you have your own.
    This thread was split from -- LM3914 resistor values for 3.7 V Li-Ion battery.
    can you please help me out of this.....
    i have tried building the same circuit.... but its not giving me a proper value.... it works for 4.2v to 0v... but i need it for 4.2 to 3v...
    its not giving me the proper output..... HAVE ATTACHED MY CIRCUIT DIAGRAM...
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
    With the circuit drawn its set for 1.25v upper limit, the adjust pin8 needs a 1.2k resistor to pin 7, and a 2.9k to ground (pin2) that will give you the upper limit of 4.2v, and a 25k from pin 4 to ground to set the lower limit of 3v.
  3. gauravkothari23
    Nov 13, 2015
    14
    I AM ATTACHING AGAIN A NEW REVISED CIRCUIT DIAGRAM.... CAN U PLEASE CHECK AND LET ME KNOW IF IT IS PORPER OR NEED SOME CHANGES.....
    THANKS.....
  4. Dodgydave
    Jun 22, 2012
    5,155
    772
    No, remove R3 and remove the link from pin 4 to pin 2, pin 8 goes to the junction of R4 and R5, R4 connects from the junction to pins 6,7.
  5. gauravkothari23
    Nov 13, 2015
    14
    @Dodgydave..... kindly request you to please check it out my new edited circuit attached here.....
    is my circuit proper or need to change something again.....
    will this work for 3.7v battery.... between 4.2v and 3v
    Thanks Again for your efforts......
  6. Dodgydave
    Jun 22, 2012
    5,155
    772
    Looks better.
  7. gauravkothari23
    Nov 13, 2015
    14
    but i tried with both 3v and 3.80v.....
    status shows is the same......
  8. gauravkothari23
    Nov 13, 2015
    14
    what is the 10kpot use for....
    i am not able to adjust anything
  9. Dodgydave
    Jun 22, 2012
    5,155
    772
    Why don't you start by telling us what you are trying to do, what voltage supply, what voltage input, then we can design it better.
  10. gauravkothari23
    Nov 13, 2015
    14
    actually i want to make a 3.7v 2600mah li-ion battery indicator.
    4.2v = battery status full.
    3.0v = battery low.
    as per your suggestions above i tried to make one circuit which is not working.
    i tried connecting two 3.7v batteries one by one....
    one of 3.80v which shows full indication and second one 3.10v which again shows full indication.
  11. Dodgydave
    Jun 22, 2012
    5,155
    772
    Ok, omit the preset R2, and connect pin 5 to pin3 supply, then when the voltage is applied it will read the supply, but the chip only works down to 3v.
  12. gauravkothari23
    Nov 13, 2015
    14
    Is it the perfect one....??
  13. gauravkothari23
    Nov 13, 2015
    14
    yes... but even at 3.80v it shows full indication.... atleast it should show 70 or 80%
    but at 3.10v it shows low indication which is perfect...
  14. Dodgydave
    Jun 22, 2012
    5,155
    772
    Ok so you need to alter the upper reference on pin6 by increasing R5, better to make R5 a 4.7k preset.
  15. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Does the voltage reference need a dropout voltage to function?
    I would set the sig in on a fixed divider and adjust the voltage reference to the divider.
    Bertus
  16. gauravkothari23
    Nov 13, 2015
    14
    sorry.... but am not getting an satisfied output....
  17. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Try the following circuit:
    Bertus
  18. gauravkothari23
    Nov 13, 2015
    14
    Even This Circuit Does not work.....
    It shows Full Indication on 4.0v And also 3.10v
  19. Dodgydave
    Jun 22, 2012
    5,155
    772
    go back to the circuit in post #12, and replace R5 for a variable one, and adjust it to give you the full scale when you input 4.2v.
  20. gauravkothari23
    Nov 13, 2015
    14
    @Dodgydave..... Have you ever visited your primary school.... i doubt you had..... because if you had visited you would have easily realized that who's a stupid person.....
    Keep your ideas.. your knowledge with you.... before blaming someone else.... have you yourself tried if your ideas work or not.....
