LM3914 resistor values for 3.7 V Li-Ion battery
Discussion in 'The Projects Forum' started by WonHungLo, Dec 18, 2013.
Thread Status:
Not open for further replies.
  1. WonHungLo
    May 9, 2011
    22
    i have the circuit built for a 12v dc monitor and i would like to adjust the values to read between 3.0V and 4.2V.
    i can not figure out for the life of me what the resistor values would be for the upper and lower limit. i know it's got to be simple.
    here is my original schematic and it works great. what would i modify to make it work on a li-ion battery.
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    datasheet remove the resistor R3 and connect pin 4 to pin 2, short out R1, this will give you a full scale of 1.25V.
    However the chip wont work below 3V, ideally it should have its own supply, and input the signal into pin 5, the led brightness is controlled by R4.
    WonHungLo likes this.
  3. WonHungLo
    May 9, 2011
    22
    does that mean the scale will be between 0V-1.25V.
    im trying to make the scale 3.0V-4.2V
  4. Dodgydave
    Jun 22, 2012
    5,154
    772
    No alter the preset resistor R2 to set the desired full scale when you connect it across the 3V battery.
  5. WonHungLo
    May 9, 2011
    22
    ok so far so good. i removed R3 and connected pin4 to pin2. when i adjust the 10k pot i can only get the lower half of the LED's to light (its a fully charged battery @ ~4.17V)
    what is the resistor i need to change to make all of them light up (i guess you would call it the upper limit)
  6. Dodgydave
    Jun 22, 2012
    5,154
    772
    short out R1, this will give you the full scale
  7. WonHungLo
    May 9, 2011
    22
    YOU ARE AWESOME. im going to post the revised schematic for anyone wanting to use this in the future.
  8. WonHungLo
    May 9, 2011
    22
    Lông Nguyễn 1 likes this.
  9. Seb1929
    Feb 20, 2015
    26
    What does the arrow that points to the 10K resistor means?
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    R2 is a trimpot (three terminals: ends and wiper)
    Seb1929 likes this.
  11. Seb1929
    Feb 20, 2015
    26
    Like this? Is it possible to change it with something else because i need the board to be as low as possible and why does i need it?
  12. paulktreg
    Distinguished Member
    Jun 2, 2008
    623
    124
    Use the trimpot for initial setup then replace it with two resistors when you've measured the values?
  13. Seb1929
    Feb 20, 2015
    26
    If so, will i only need to do it on one board? Because i don't want to do it on 1000 boards :p
  14. MikeML
    Oct 2, 2009
    5,451
    1,066
    You should read this other thread...
  15. Seb1929
    Feb 20, 2015
    26
    Why? I have found out how to do it.
  16. MikeML
    Oct 2, 2009
    5,451
    1,066
    Care to share it with us?
  17. Seb1929
    Feb 20, 2015
    26
  18. MikeML
    Oct 2, 2009
    5,451
    1,066
    I was more interested in the underlying science of being able to determine the state of charge of batteries using a voltmeter.
  19. Seb1929
    Feb 20, 2015
    26
    The LM3914 chip does it so..
  20. MikeML
    Oct 2, 2009
    5,451
    1,066
    Sorry to burst your bubble... The 3914 is nothing but a voltmeter, and not a very good one at that!
Thread Status:
