LM3914 Question
Discussion in 'The Projects Forum' started by iONic, Oct 29, 2010.
  1. iONic
    Thread Starter AAC Fanatic!
    Nov 16, 2007
    1,422
    68
    I believe this is possible.
    Not that I want to do this exactly, but can you tie LED Outputs 0 & 1, 2 & 3, 4 & 5, 6 & 7, 8 & 9 each to a single LED, thus creating a 5 LED indicator instead of a 10 LED indicator? And in doind so, without any additional parts?
    Can they be staggered... Output 0 to one LED, Output 2 & 3 to another LED...?
    Can you tie three outputs to one LED, and perhaps 1 per LED for the remainder?
    Thanks guys!
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Should be no problem in "DOT" mode. If "BAR" mode is used, the outputs would combine their currents. Others may see it differently and straighten out my thinking. Is there a reason you would not be able to just use the first 5 outputs and scale your input accordingly?
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    From the datasheet:
    If you halve the output drive via pin 7 on the LM3914, you could use 2 pins to sink enough current to not overdrive 1 LED.
    All outputs would need to be dual output for 1 LED though, it may be easier to go 50% = full scale, and only use the first 5 comparators to avoid any problems.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can't cheat
    the datasheet.
    If you try,
    Your parts will die.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    This would be bad,
    And you would be sad.
  6. iONic
    Nov 16, 2007
    1,422
    68
    You guys are too funny.
    If you do not use output 0 - 9 can the voltage range be as large, for example using only outputs 0 - 5...?
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    The IC is designed for a 0-5V display, each LED being 0.5V.
    Change/Add voltage divider on input so the max is only 2.5V instead of 5V. Use the first 5 taps. Some resolution is lost, but that would happen in any case when going from 10 to 5 outputs, no matter the method.
  8. R!f@@
    Apr 2, 2009
    8,785
    771
    LMAOF....Sorrry.
    Like seeing humor every now and then.
