LM3914 - Expanded Scale Voltmeter - Help!
Discussion in 'General Electronics Chat' started by joe426, Jan 15, 2012.
  1. joe426
    Thread Starter Active Member
    Aug 11, 2009
    39
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Did you download the datasheet?
    On page 9 there is an example how to expand the range.
    Bertus
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    What is you supply voltage?
  4. joe426
    Aug 11, 2009
    39
    Yes, I've thoroughly looked at the documents I linked to above. They're really poorly written in my opinion and I'm having trouble following them (hence why I asked for help).
    I have two available rails. ~9v and 5v.
  5. Dippo
    Oct 24, 2011
    8
    Dave Jones from EEVBlog made a really great tutorial about a battery tester using a LM3914. It's on Youtube.
    Link.
  6. joe426
    Aug 11, 2009
    39
    Yeah, I linked to that video in my original post. He does a good job overall, but is still confusing about customizing a range.
    Isn't there a simple set of equations with resistor values? I don't see why this is so difficult. :confused:
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    This circuit should do the job
      File size:
      24.3 KB
      140
      File size:
      25 KB
      113
  9. joe426
    Aug 11, 2009
    39
    It will work for 4.25 to 5v? Is that what you're saying?
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, It will work from 4.25V to 5V As you mention in your first post.
    But you can easily adjust the range by using a potentiometer.
  11. joe426
    Aug 11, 2009
    39
    What would the resistor values need to be if the range was .5 to 3 volts?
    Thank you!
