Lm386
Discussion in 'General Electronics Chat' started by ojou-san, May 19, 2013.
  1. ojou-san
    Jan 7, 2013
    20
    Hello. I wanna ask how come Power Converters and Ultrasonic drivers became an application for LM386. How do I use LM386 in those applications? What is power converters?What does it do? What is an Ultrasonic drivers? What does it do?:confused::confused::confused:
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    I have no idea what you are saying.
    Ask one question at a time.
    What are you trying to do?
    MMH likes this.
  3. ojou-san
    Jan 7, 2013
    20
    Sorry about that. Well I don't know about power converters and ultrasonic drivers and our professor is telling us to use LM386 in power converter and ultrasonic driver.So how do I use LM386 in power converter and in ultrasonic driver?
  4. timescope
    Member
    Dec 14, 2011
    298
    44
    The Texas Instruments' LM386 datasheet lists those applications. The bandwidth with pins 1 and 8 open is 300kHz so it could be used in those applications although it is described as an audio amplifier.
    Timescope
    ojou-san likes this.
  5. tubeguy
    Nov 3, 2012
    1,157
    197
    Did your professor give you any specifics ?
    If so, please post that info.
  6. GopherT
    Nov 23, 2012
    6,300
    4,020
    Ojou-san,
    Normally, devices that generate signals (op Amps, logic chips, crystal oscillator circuits), do not have enough power to do anything more than generate signals. Therefore, you need to connect these signal generating devices to a "driver". A driver is a circuit that can amplify the input signal to provide sufficient power to any motor, loudspeaker, ultrasonic horn or other device that can really make something happen.
    Although the LM386 is referred to as an "audio amplifier", it can amplify any signal in the audio frequencies (and even above) for non-audio applications. Audio frequencies are generally from 20 Hz to about 20k Hz. The LM386 will be useful from DC to 30k Hz (10x amplification) to 100kHz (3x amplification).
  7. MrChips
    Oct 2, 2009
    12,623
    3,451
    A driver does not need to amplify the signal. What it needs to do is drive enough power.
    Power is calculated as P = IV or using all combination of Ohm's Law I = V/R.
    What is missing from your discussion is the load resistance R.
    You need to discuss what is the load R.
  8. ojou-san
    Jan 7, 2013
    20
    He didn't give any specifics rather he just told us to research about the significance of active filter into the power converter and in ultrasonic drivers. He just told us that ultrasonic drivers has something to do with pressure. :(
  9. ojou-san
    Jan 7, 2013
    20
    Thanks for that explanation. I already tried doing that. I used LM386 as an audio amplifier and it really works when I tried in Multisim. But my problem now is what does it do in Power Converters and in Ultrasonic Drivers?
  10. MrChips
    Oct 2, 2009
    12,623
    3,451
    Can you talk about one application at a time:
    1) Power converter
    What is your load impedance?
    How much power?
  11. ojou-san
    Jan 7, 2013
    20
    Well He didn't tell anything in particular. Just Power Converter. Maybe any value as long as it is power converter.
  12. MrChips
    Oct 2, 2009
    12,623
    3,451
    Well you will have to come up with your own specs.
    Calculate the current and voltage requirements for various loads from 1Ω to 1MΩ.
  13. ojou-san
    Jan 7, 2013
    20
    My own specs? hmmm
    current? how about 1.5 amps?
    all 50 Ω
    with a voltages of 25V,50V,75V and 100V?
  14. MrChips
    Oct 2, 2009
    12,623
    3,451
    No! No! No!
    We're talking about an LM386, aren't we?
  15. ojou-san
    Jan 7, 2013
    20
    Ah Ok I get it. Sorry about that. I thought it was about power converter. 3-15VmA and the voltage? 5V?
