LM386: Setting Gain with resistor-cap networks
Discussion in 'General Electronics Chat' started by Zaraphrax, Sep 22, 2010.
  1. Zaraphrax
    Thread Starter Active Member
    Mar 21, 2009
    47
    Hi all,
    Sorry for the newb question - but is there an easy "rule of thumb" or some precise method for the LM386 on how to pick the resistor and cap values to set the gain. The datasheet doesn't seem to have a formula (you can find the datasheet available here: http://www.national.com/mpf/LM/LM386.html)
    Thanks.
  2. retched
    Dec 5, 2009
    5,201
    313
    Wow. Thats kind of odd.
    They only tell you how to get 200 from the preset 20. AND they tell you that it is possible by using 'resistors' but they dont give a formula.
    Time to check the App notes.
    Here you go:
    Zaraphrax likes this.
  3. Zaraphrax
    Mar 21, 2009
    47
    retched,
    Thanks very much! That's sorted me out now. :)
  4. retched
    Dec 5, 2009
    5,201
    313
    No problem, friend.
    I cant believe this info is not in the data sheet...
