LM386 guitar amp
Discussion in 'General Electronics Chat' started by jeffblev, Jul 12, 2009.
  1. jeffblev
    Jan 1, 2008
    I see a lot of LM386 based simple guitar amplifier circuits like the following:
    The national datasheet states that the input is referenced to ground but that the output is referenced to 1/2Vcc. If your input is referenced to ground though, won't this clip a guitar signal?
    What am I missing?
  2. Audioguru
    Dec 20, 2007
    The LM386 is a power amplifier, not an opamp.
    It is designed to be biased correctly when its input is at 0V and when it has a single supply polarity.
    It has built-in negative feedback that keeps its output DC voltage at half the supply voltage for maximum output swing. The negative feedback sets its gain at 20 (or at 200 if a capacitor is added between pin 1 and pin 8) and reduces its distortion.
    It has symmetrical clipping like any audio amplifier.
  3. jeffblev
    Jan 1, 2008
    Thanks AudioGuru :)
