LM386 guitar amp = radio?
Discussion in 'General Electronics Chat' started by daroc26, Feb 13, 2010.
  1. daroc26
    Thread Starter Active Member
    Apr 4, 2009
    30
    Hi All,
    I built the Little Gem Amp on a breadboard and it plays somewhat as expected. However, now it is picking up a local radio station.
    Could anyone explain this?
    Thank you![​IMG]
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You say now it picks up the station. Was there a time that it did not pick up the radio station?
    hgmjr
  3. daroc26
    Apr 4, 2009
    30
    Yes.
    Today, I added a SPST On-Off Switch, a 1k resistor and a green LED.
    I'm not sure how this would make it pick up a radio signal.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Where did you place the added components? The presence of the LED could be providing the rectification that when combined with the high gain of the amplifier pulls the radiostation audio out of the noise.
    hgmjr
  5. daroc26
    Apr 4, 2009
    30
    I have a long breadboard. On the left hand side is the lm386 circuit and components and on the far right I put the resisted and LED and power.
    Crummy webcam pic after the break...
  6. flat5
    Nov 13, 2008
    403
    17
    Did you also add a guitar chord and/or guitar?
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    I believe what is needed is bypass capacitors on the power supply. If you have a large electrolytic capacitor and a 0.1 ufd or 0.01 ufd capacitor in your parts stash then put both of them across the power supply to filter it.
    hgmjr
  8. daroc26
    Apr 4, 2009
    30
    Yes, I should've mentioned...the guitar is connected when the radio signal comes through.
  9. daroc26
    Apr 4, 2009
    30
    Okay, that would make sense! I'll give that a try!
    Thank you for your help!
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    If the power supply pin bypasses dont do anything, and I predict that they won't, I may have a fix. Building the circuit into a metal box will go a long way in fixing it. Putting an RF bead on the input wire, and possibly shunting the input pin on the PA with a 100pF or 470pF may help, too.
    Question: How close to you is the nearest MW AM broadcast transmitter? You are using a shielded lead between the guitar pick up and the amp, right? Shield is connected to Pin 4, right?
  11. daroc26
    Apr 4, 2009
    30
    I'm not sure about the nearing AM transmitter...Radio is still coming across, after putting a 350uf cap across the power supply. When I'm ready to build I'll use a metal box for sure.
    Thanks for the suggestions!
  12. MikeML
    Oct 2, 2009
    5,451
    1,066
    How about the shielded wire question?
  13. hgmjr
    Jan 28, 2005
    9,030
    214
    In addition to the 350ufd you will need to put a 0.1 ufd or a 0.01 ufd bypass capacitor across the power supply very close to the power pins on the LM386.
    hgmjr
  14. MikeML
    Oct 2, 2009
    5,451
    1,066
  15. hgmjr
    Jan 28, 2005
    9,030
    214
    You are probably right but it is a cheap experiment nonetheless. These bypass capacitors are a good thing to provide as a general rule.
    hgmjr
  16. flat5
    Nov 13, 2008
    403
    17
    I'd start by putting a 0.001uf cap from the input (pin2) to ground. If not successful, add the rf bead at the input socket. A resistor to ground at the input may be a good idea to protect the IC.
    Maybe a 1 megohm or less.
    Short leads and a metal box will certainly help,
    but you need some input conditioning.
    Use a good guitar cord with clean plugs.
  17. retched
    Dec 5, 2009
    5,201
    313
    Could you opto-isolate before preamping? It would seem if you isolated the guitar cord from the rest of the circuit, you would reduce possible antenna.
  18. flat5
    Nov 13, 2008
    403
    17
    Hi retched. Then you would need a preamp to drive the opto. The radio could sneak in from that preamp. Sneaky RF :)
    You would just be adding complexity and distortion. I think.
  19. nomurphy
    Aug 8, 2005
    567
    12
    Please see the attached PDF, all the below should help with AM noise to one extent or another.
    The power supply inductor value is not critical, but try to find one around 10 uH that has 1/2 ohm to 1 ohm DCR.
    The LM386 has a 50K input resistor, the added resistor and cap on the input help match guitar cable capacitance (among other things).
    Since you're using this to drive speakers, adding the inductor at the output Zobel network may help (see note in schematic).
    I did not show the two pots or pins 1 & 8, but when using pins 1 & 8 then pin-7 should be bypassed as shown.
    Your layout and grounding is also critical, but that is another topic entirely.
  20. flat5
    Nov 13, 2008
    403
    17
    Good work but if you want to go to that extent then include an RF bead (or two) on the input.
    Edit: Thinking for a minute I realize a musician may play anywhere - including next to an antenna farm or a trucker's party with lots of CB radios.
