Hey all,
I have some serious questions regarding the following circuit:
This is the internal schematic for the LM384 5W power amplifier. I've been studying analog design and I analyzed what I could from this circuit, which is all the DC operating points, and the function of each 'piece' of the circuit. I was interested in some parts of the circuit, specifically those which gave me a real headache when trying to do some AC analysis. I took to SPICE to try and simulate the circuit, and it worked as described, with about 50 gain (33dB) at audio frequencies and above, but I actually couldn't use the transient analysis to figure out what was going on in some places. See below.
Confusing points: The two transistors on the bottom right, a PNP from the 10pf capacitor, and an NPN connected to its collector and emitter in some sort of PNP sziklai pair setup. By my calculations, and then SPICE, these are not biased on during normal operation. But they're surprisingly close. Is this some protection in case of a larger amplitude signal or a fault on my part?
Next: the 25k resistor in the middle of the schematic. At first I thought it was a feedback resistor, since it connects from the output back to near the input. But what bugs me is the resistor seems to be integrated into the amplifier- at DC it sets (or helps set) the output operating point, and at AC I don't even know what it does. It's connected to the emitter output of a differential amplifier, so it sees the input signal on that end, and it sees the output signal on the other, giving some difference voltage drop. I don't get it- what is going on with that resistor.
Finally: I believe the ultimate gain of this device comes from the differential amplifier and the NPN transistor in the bottom right with a 10pf capacitor connected from base to collector. This might seem to make sense, but honestly I can't come up with why that capacitor is there for a start, and second I have my doubts about whether those two stages supply all the gain. It comes back, I guess, to the 25k resistor, and in general whether or not the circuit uses negative feedback, which seeing how flat the response is and controlled the gain is I'd say it is more than likely it does. What do you all think about this circuit? Can some brilliant soul make heads or tails out of this and clear up some of these points? Thanks in advance!
Sam Gallagher
P.S. Attached is my SPICE sim in LTSpice
Sam Gallagher
