LM380 oscillates on positive
Discussion in 'General Electronics Chat' started by jmoffat, Nov 29, 2015.
  1. jmoffat
    Jul 18, 2012
    42
    I breadboarded the audio amplifier in the circuit below. My O'scope indicates that it is oscillating on the positive half of the sine wave. Any ideas? I used the inductor symbol to represent the speaker. If anyone knows where I can find a LTspice model for a LM380 please share. Also what would be a reasonable model for a 2" speaker?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,367
    642
    Do you have the power supply decoupled? Is the oscillation frequency low enough to be audible?
    Post a schematic for those of us who might be using a device that doesn't have LTspice installed.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    Can you post a readable schematic?
    Do you have the resistor/capacitor combination on the output of the LM380?
    Bertus
  4. jmoffat
    Jul 18, 2012
    42
    Yes the power supply has a 220 uf cap which I moved to be physically closer to the opamp.
    What is a good way to generate a jpeg of my schematic?
  5. dl324
    Mar 30, 2015
    3,367
    642
    You need a ceramic capacitor for good high frequency decoupling.
    Depends. Are you using a schematic editor? Or drawing on paper?
  6. jmoffat
    Jul 18, 2012
    42
    I will have to find a way to generate a jpeg or something that can be displayed easily.
    and yes I do have the resistor / capacitor in place. Ironically the oscillation diminished
    substantially when I disconnected it. This led to me dress the leads differently. Problem solved!
    I never thought lead dress would be critical at 1KHz!
  7. dl324
    Mar 30, 2015
    3,367
    642
    Breadboarding can introduce all sorts of coupling and parasitics.
  8. RichardO
    May 4, 2013
    1,334
    429
    Your signal may be at 1 KHz but the amplifier has gain at hundreds of kHz or more. This gain at high frequencies with some feedback can cause oscillations from the parasitics dl24 mentioned.
  9. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    Make a screenshot of the simulator you use and post it here.
    Bertus
  10. MikeML
    Oct 2, 2009
    5,450
    1,066
    @jmoffat , Is it the LTSpice sim that is oscillating, or is it the real circuit?
    Can you post the spice model you are using?
  11. Bordodynov
    May 20, 2015
    669
    194
    There is no symbol, but a symbol of the resistor can be used.
  12. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    In post #3 by Bertus, there is a 2.7 ohm plus 0.1 uF snubber on the output. Do you have that installed? In 1979, I worked on a commercial product where the original engineer did not put in the snubber, and there were severe problems. The LM380 worked as an amplifier, but was very soft. My theory was it was putting out most of its power at the high frequencies of the ringing (oscillation). Once the 0.1 uF cap was installed, the output became normal.
  13. AnalogKid
    Aug 1, 2013
    4,676
    1,294
    As a rule of thumb, audio power amp chips, old and new, are notorious for breaking into oscillation. They are very sensitive to ground impedance (long wires/thin traces), decoupling, etc. Almost all have reference designs in the datasheet or app notes, and that board layout is not just recommended. Often it is the only thing that will keep the device under control.
    ak
    OBW0549 and Roderick Young like this.
  14. eetech00
    Jun 8, 2013
    674
    115
    I made a symbol and created a spice model.
    Bordodynov likes this.
  15. Bordodynov
    May 20, 2015
    669
    194
    eetech, join please symbol element and test scheme.
  16. eetech00
    Jun 8, 2013
    674
    115
    Hi Bordodynov
    I'm not sure what you mean....please clarify.
  17. AnalogKid
    Aug 1, 2013
    4,676
    1,294
    Attach the files.
    ak
  18. eetech00
    Jun 8, 2013
    674
    115
    Hi
    LTspice files attached.
