LM358 Square Wave Oscillator Help
RKG
Joined Apr 5, 2011
I am going to be using a LM358 as a Square Wave Oscillator for a college project but am having some trouble in calculating what Resistor and Capacitor values I'll need to use to produce a frequency of 1Hz. I'll be using the oscillator on pg 14 of this document: http://www.national.com/ds/LM/LM158.pdf
I've found many equations during my research but am unable to find one that relates to the LM358.
The most common equation I have found is: T=2RC ln[(1+λ)/(1-λ)] Where λ=R1/R1+R2
Of course this does not take into account R3 of the LM358 circuit. Can I leave R3 out of the equation or do I change the equation to this: λ=R1/R1+R2+R3 ?
Any help would be much appreciated.
Jony130
Joined Feb 17, 2009
5,488
For your circuit supply form single supply voltage equation for T1 is equal
\(T1=R1*C*\ln \frac{Vcc - VL}{Vcc - Vh} \)
T2 is equal
\(T2=R1*C*\ln \frac{Vh}{VL} \)
\(Vh = Vcc*\frac{R3}{R3 + R4||R2}\)
\(VL = Vcc*\frac{R3||R4}{R3||R4 + R2}\)
Of course I assume that opamp gives VCC in high state and 0V in low state.
So if we assume R2=R3=R4 we have
\(Vh = Vcc*\frac{R3}{R3 + R4||R2} =\frac{2}{3}*Vcc\)
\(VL = Vcc*\frac{R3||R4}{R3||R4 + R2} =\frac{1}{3}*Vcc \)
So finally
\(T1=R1*C*\ln \frac{Vcc - VL}{Vcc - Vh} = R1*C*\ln2 = 0.693*R1*C\)
\(T2=R1*C*\ln \frac{Vh}{VL}=R1*C*\ln2 = 0.693*R1*C \)
Time period
\( T=T1+T2 = R1*C*\ln4 = 1.386 R1*C \)
So for 1Hz R1 = 220K C = 3.3uF
And if you choose R2 = R3 = R and R4 = 0.52*R then
T = 2* R1 *C
For C = 470nF; R1=1M
