LM3578 prelab help
Discussion in 'Homework Help' started by KCHARROIS, Jan 20, 2013.
  1. KCHARROIS
    Jun 29, 2012
    292
    Hello
    So I'm trying to complete a prelab with the LM3578 switching regulator and I'm having a problem calculating C2. I'm following the example for the Buck Converter circuit and the formula for C2 is:
    C2 ≥ Vo (Vin - V0) / (8 * Fosc2 * Vin * Vripple * L1
    The given values in there example are:
    Vin = 15
    Vo = 5
    Vripple = 0.01
    L = 470u
    Fosc = 50 KHz
    C2 answer is 200uF rounded off i'm assuming
    My calculation is 5 (15 - 5) / (8 * 50KHz2 * 15 * 0.01 *470uH) = C2 35.4uF
    Where did I go wrong?
  2. KCHARROIS
    Jun 29, 2012
    292
    Rethinking about my problem does mean that any value of 35.4uF or greater is an acceptable capacitor value and that they chose 220uF?
  3. tshuck
    Oct 18, 2012
    3,531
    675
    It would appear that that is the case, I got the same value.
    We never want to design a circuit, particularly, a supply, to operate at the margins. It would seem that they chose this arbitrarily to give a large amount of leeway, though I can't be taken as an expert in this arena.
    For anyone wanting to verify, the formula is listed on page 16 in the datasheet.
