lm35 with ni daq problem
Discussion in 'The Projects Forum' started by mah, Feb 6, 2014.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    i use usb6008 daq to acuire signal from lm35 but the output of the sensor is affected when connecting the daq on its output , the out of the sensor is .45 volt when connecting the daq it reads the output less than the real output by .04 and this value decreased when the output increased . should i use optocoupler or what do you think ?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    I don't know anything about your DAQ, but my lm35 is connected directly to my ADC with no issue. You need to check the input impeadance spefification of your DAQ. It should be several megohms. If that is the case, then you have a setup issue. It that's not the case, then you need a high input impeadance unity gain amplifier between your lm35 and DAQ.
  3. TANDBERGEREN
    Member
    Jan 20, 2014
    74
    If any problems with iimpedance, it is quite simple to use nearly any OP-amp as a voltage follower to fix that problem.
  4. ronv
    Nov 12, 2008
    3,404
    1,478
    You need a negative supply for it to be good to 0C. See fig. 1 &2 in the datasheet.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    If I remember correct the input impedance of the 6008 is quite(very) low for a DAQ device. But before I dive into this case post your schematic
  6. TANDBERGEREN
    Member
    Jan 20, 2014
    74
    On page 8 in the datasheet (National Semiconductor November 2000) there is two good examples of connecting it directly to a ADC.
    But there is no problem using the datasheet as a direct source for Your design.
  7. mah
    Mar 15, 2010
    276
    the output is directly connected to the ADC , in my design i used 10 Kohm in series with the lm35 and a 1 μf capacitor as RC damper
  8. t06afre
    May 11, 2009
    5,939
    1,222
    This is the input stage of your DAQ unit. Also shown in the manual page 11 http://www.ni.com/pdf/manuals/371303m.pdf As we can see it is a very poor design. In most cases an opamp buffer stage before the input will be required
  9. TANDBERGEREN
    Member
    Jan 20, 2014
    74
    Not a good design.
    Use a LM101 or similar.
    connect the output of the LM35 to the non-inverting input
    Connect the inverting input to the output.
    Connect the output of the OP-amp to the DAC input.
    Any damping is not necessary.
    But if You find it so anyway, then put the damping on the OP-Amp input.
    Have a look here: http://pdf1.alldatasheet.com/datasheet-pdf/view/8594/NSC/LM101.html
