LM35 sensor
abu zuhdi
Joined Apr 1, 2008
hello everybody
i want some help about how to transport the output signal of the LM35
to a microcontroller which is 10 to 13m away from the sensor what should i do, and i need a design for an amplifier to the signal
SgtWookie
Joined Jul 17, 2007
22,230
You should go to National's website and download their datasheet for the LM35.
Check out the Applications section. One application deals with using an ADC IC near the LM35 to digitize the signal early, before noise gets on the analog output.
I would not suggest trying to amplify the LM35 output, nor running it for long distances.
