lm35 problem
Discussion in 'The Projects Forum' started by mah, Jan 20, 2014.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    i use lm35 to measure the temperature surface of photovoltaic panel when i feed it with 2.6 v supply it give output 0.754 this is related to 75 °C when i increased the supply voltage to 4 v and more it give 0.44 v related to 44 °C
    Is that normal or i have defected sensor ?
  2. wayneh
    Sep 9, 2010
    12,389
    3,245
    4V is the minimum specified supply voltage. Below 4V, I wouldn't pay any attention to the output.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    What is the actual temperature?
    Line regulation is only specified between 4V and 30V according to the datasheet. At what voltage do you want to use the IC?
  4. mah
    Mar 15, 2010
    276
    any voltage is available but i have doubts of output
  5. wayneh
    Sep 9, 2010
    12,389
    3,245
    Why? You've only cited one result (which is plausible depending on what you are doing with it) taken at the absolute minimum supply voltage. Try 9V and see what you get.
    By the way, it's just as easy to wire this wrong as any other component. Mine survived miswiring at 5V but not when I turned up the voltage. Double check before you do that.
  6. TANDBERGEREN
    Member
    Jan 20, 2014
    74
    When powered with a too low voltage, the output will not be reliable.
    Give it a minimum of 5V and the output will be as specified.
  7. ErnieM
    Apr 24, 2011
    7,439
    1,627
    If you remove the supply altogether will you trust the voltage output?
    (There's a lower limit if you want reliable operation.)
    Ultimately, your validation testing should remove all your doubts.
