LM35 fridge thermostat
Discussion in 'The Projects Forum' started by CornelAndrew, Nov 6, 2012.
  1. CornelAndrew
    Nov 6, 2012
    I need to replace the mechanical fridge thermostat which is not working. Because i can’t find a similar model, i decided to build this schematic.
    http://www.escol.com.my/Projects/Project-03(Thermostat-1)/Proj-03.html
    It is working well, but only for positive temperatures. I need the schematic to operate from -5 Celsius to +4 Celsius (to use VR1 to se the temperature inside the fridge in the range of -5 Celsius +4 Celsius).
    The schematic is using LM35DZ (0 Celsius to 100 Celsius). I’m using LM35CZ (-55 Celsius to +150 Celsius). What else should i modifiy?
    Because i’m using a 5,2v stabilized power supply, i operated the following modifications:
    1.ZD1, R6 are out. R5 is 550 ohm.
    2.VR1 is 5K instead of 2,2K (i couldn’t find a 2,2K pot)
    I measured the voltage in some points. At 22 Celsius:
    TP1> 1,42v
    Pin2 of LM35 > 1,48v
    Pot hot wire > 1,42v
    At -2 Celsius
    TP1> 1,90v
    Pin2 of LM35 > 1,27v
    Pot hot wire > 1,90v
    Datasheet
    http://www.ti.com/lit/ds/symlink/lm35.pdf
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    I recall they needed a pull down resistor (to a more negative potential) to swing the output negative. That would be from pin 2 on your LM35 to the negative 12V line in the schematic. Accuracy will be poor because your negative "reference" is just two diodes. Note: all of the signal levels are with respect to "ground" in the circuit which is NOT the negative 12V line.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    bountyhunter is right.
    In the datasheet this is given to measure negative temperatures:
    A negative voltage is a needed to measure negative temperatures.
    Bertus
  4. CornelAndrew
    Nov 6, 2012
    Thank you. So if i'm using a 5,2v supply, what should be the value of R1? I don't know how to calculate ...
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    Unless you use a LM34DZ, which will go well below 0°C.
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    The LM34 is calibrated in degrees fahrenheit.
    The LM35 is calibrated in degrees celcius.
    If you want to use the LM34 the setpoints need to be recalculated.
    (fahrenheit to celcius conversion).
    Bertus
  7. Dodgydave
    Jun 22, 2012
    5,134
    767
    R1 would be 1.2V/ 50uA =24K nearest value is 22K.
    The LM35 gives out 10mV per 'C so at say 5C it will give out 50mV, once it goes below zero C, it become resistive and so you need to provide a resistor to pull it down,
  8. crutschow
    Mar 14, 2008
    13,469
    3,356
    The accuracy does not depend upon the accuracy of the negative voltage. The negative voltage is just to bias the low impedance output stage so it can generate a negative output voltage.
