LM35 connected to op-amp
Discussion in 'Homework Help' started by aab09, Dec 22, 2014.
  1. aab09
    Dec 12, 2014
    Hi
    I need your help. My project is to design sensor that connected to op-amp.
    temperature range from 35°C – 45°C, and ADC range 0 – 3.3V.
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    So what have you already done?
  3. aab09
    Dec 12, 2014
    actually, nothing
    I need some hints to begin designing
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    Well, I would start by reading the data sheet for the LM35
  5. Dodgydave
    Jun 22, 2012
    5,139
    767
    The sensor gives out 10mV per degC, 35C to 45C thats a voltage output of 350mV to 450mV,
  6. Alec_t
    Sep 17, 2013
    5,966
    1,133
    .... so you need to amplify and offset those mV to get 0-3.3V (ideally). Read up on opamp theory.
  7. aab09
    Dec 12, 2014
    I asked the doctor about it he tell me to get output voltage of opamp=0 when T=35, output voltage of opamp=3.3 when T=45
  8. MikeML
    Oct 2, 2009
    5,450
    1,066
    We, instead just giving you the answer, in which case you learn nothing, are waiting for you to show some initiative and suggest a solution...
    btw- I am a retired doctor (PhD). If you were my student, I would fail you if I learned that you just copied a solution that someone handed to you.
  9. ScottWang
    Aug 23, 2012
    4,925
    777
    So now you should figure out how a op amp to do the amplifying as inverting and non-inverting, and then draw the circuit and attach it here.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    You will note that everyone assumes this is home work, which means it gets treated differently. Make a serious attempt to solve the problem, draw a schematic you think might work, and you will go further. The more input you give the more hints toward solutions you will get, and the more you will learn.
