lm339
Discussion in 'General Electronics Chat' started by Dritech, Apr 3, 2012.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    Is the LM339 output a digital output (schmitt trigger) ?? and is it good to compare small voltages such as 0.3V ?
    Thanks in advance
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Yes and Yes.
    The LM339 is open collector output.
    is not the right question.
    Comparators work by comparing one input with another.
    You can set a reference voltage to whatever voltage you wish as long as you satisfy the input operating range.
    Dritech likes this.
  3. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply. Another question; is there a similar IC but with a single or double comparator which is not SMT?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yes. A LM393. It is a 8 pin dual.
    SMT packges are optional, refer to the data sheet. You can get a LM339 from Radio Shack as a 14 pin DIP.
    Dritech likes this.
  5. Dritech
    Sep 21, 2011
    756
    5
    Hi again,
    I bought the LM393 but its not outputting 5V when Vin exceeds Vref. I connected the circuit as shown in the attachment.
  6. MrChips
    Oct 2, 2009
    12,636
    3,454
    Many comparators, including the LM393 are open-collector, which means the output is uncommitted. Put a pull-up resistor from the output to +5V. Any value from 1K to 10K ohm should work.
  7. Dritech
    Sep 21, 2011
    756
    5
    What does open-collector mean? and is there a similar IC with a Schmitt Trigger?
  8. kingdano
    Member
    Apr 14, 2010
    377
    19
  9. Dritech
    Sep 21, 2011
    756
    5
    Ok, thanks for the link.
  10. crutschow
    Mar 14, 2008
    13,501
    3,375
    "Open-collector" means the output consists of a single transistor (NPN here) with the collector open and the emitter to ground. Thus you need to add a resistor from the collector to V+ to see the output change state.
    It you look at the data sheet (heaven forbid) you will see this.:rolleyes:
    This output transistor turns off (output goes high) when the plus input voltage is greater than the minus input voltage.
    I don't know of any comparator ICs with a build-in Schmitt trigger but you can add hysteresis (which acts as a Schmitt trigger) to any comparator by adding a small amount of feedback from the output to the plus input using a pair of resistors.
    Dritech likes this.
  11. Dritech
    Sep 21, 2011
    756
    5
    Thanks. If i add a pull up resistor, it should work as a schmitt trigger, right?
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    No. A Schmitt Trigger is a specific type of circuit.
    You can make a Schmitt Trigger with a comparator or op amp, or even a 555 (which does it totally different).
    A comparator only outputs a one or a zero, a op amp outputs a linear voltage.
    Positive feedback
    555 Schmitt Trigger
  13. crutschow
    Mar 14, 2008
    13,501
    3,375
    No.
    Perhaps you are confusing a comparator function with a Schmitt Trigger function.
    A comparator changes output state from high and back to low at nearly the same input voltage (as determined by the open loop gain of the comparator amplifier).
    A Schmitt trigger is a type of comparator that has hysteresis, which means it changes to output state high at one level of input voltage and changes back to output state low at a different level of input (a lower voltage for positive voltages) to minimize oscillations from noise or stray feedback.
    Standard comparators do not have this hysteresis built-in and it must be added by a small amount of positive feedback from the output to the plus input, as I stated in my previous post.
  14. Ron H
    Apr 14, 2005
    7,050
    657
  15. Wendy
    Mar 24, 2008
    20,772
    2,540
  16. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, that's what I was thinking. I don't think those comparators are for beginners, so I hesitated to mention them, but anal, compulsive geek that I am, I did it anyhoo. So there.:p
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    The key thing about Schmitt Triggers is their hysteresis. They switch at two different voltages.
    http://en.wikipedia.org/wiki/Schmitt_trigger
    The vast majority of comparitors (so there Ron!) compare the two input voltages, and have a one or a zero depending on which voltage is greater. A common nick name for a comparitor is a single bit A/D converter. They can also be used to make full scale A/D convertors.
    http://en.wikipedia.org/wiki/Comparitor
    An op amp and a comparitor are related, but a comparitor is designed to only output a digital value, whereas a op amp is a linear circuit.
    You can make a true Schmitt Trigger with either a op amp or a comparitor and two resistors, but since comparitors are truely digital they are much faster.
    Open collector is also a common digital technique in the I.C. world.
    http://en.wikipedia.org/wiki/Open_collector
