Lm339 Voltage LED indicator (S.0.S)
Discussion in 'General Electronics Chat' started by shorabkareem, Jun 19, 2012.
  1. shorabkareem
    Jan 19, 2012
    6
    Can anybody please help me. I need to have a wiring Schematic as how i can build a LM339 voltage indicator with LED as indicators
    to connect to my Lm317 voltage regulator circuit (out put from 1.25 V to 30 V) which i have already built.
    I am complete beginner to electronics therefore, please explain to me in very simple electronic terms with clear guidelines.
    * will appreciate if you can show me as how i can connect one or two more LM339 IC if i want to increase the LEDs.
    tks : sdk
  2. praondevou
    Jul 9, 2011
    2,936
    489
    The maximum output current is specified for 20mA so it is maybe good for 1 or two LEDs. If you want to use more you need a buffer (simple transistor stage).
    You didn't say at what voltages it should indicate something. What condition do you want to indicate? Overvoltage undervoltage? What hysteresis, if any?
  3. #12
    Nov 30, 2010
    16,685
    7,323
    You might want to look at this chip.
  4. shortbus
    Sep 30, 2009
    4,095
    1,681
  5. Bernard
    Aug 7, 2008
    4,240
    414
    3.1 pages is over-kill; how about Forrest Mims III's Bargraph. If top of R2 is set to 4 V, then each step will be one V
  6. shorabkareem
    Jan 19, 2012
    6
    Thank you for you quick response
    But please note i need to have wiring diagram as which + & - wires goes to the 339 ic (supply and Ground) and which wires goes to the voltage input from my 317 voltage regulator. can i use one supply (battery) to power the whole Ic
  7. shorabkareem
    Jan 19, 2012
    6
    I need the LEDs to blink (ON) to indicate voltage in sequential order 6 V, 12v, 20v and 24v etc.
  8. Bernard
    Aug 7, 2008
    4,240
    414
    If input is 7V, would a LED indicating 6V to 12V be acceptable, or just 6V +- 1/4V. How many steps?
  9. shorabkareem
    Jan 19, 2012
    6
    i don't mind the voltage sequence but i need the LED to indicate in 04 step or more to show there were voltage increment.
    how much supply voltage do i have to used for the 339 ic?
    my input voltage is from 1.25 v to about 30 v
  10. #12
    Nov 30, 2010
    16,685
    7,323
    This datasheet tells what the LM339 chip needs to operate properly.
  11. Bernard
    Aug 7, 2008
    4,240
    414
    In a bar graph display when reading top V, all LEDs are on, not great for battery operation if on for long time periods. A 5 or 6V regulated wall wart is a possibility. No labled schematic is possible without knowing number of steps & V assigned to each step. It is easier if all steps are uniform, but not required -- just makes a verry messey V divider.
