LM339 set-points
Discussion in 'General Electronics Chat' started by Dritech, Dec 1, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
    How can I calculate the values for the resistors which will be used in a voltage division configuration to set 6 different voltage set-points?
    So basically I know Vcc, the set-points voltages and need to determine the resistors' values.
    Thanks in advance.
  2. kubeek
    Sep 20, 2005
    4,687
    805
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    What voltages do you need ?
    You can calculate a quick divider string by thinking of it as 1000 ohms per volt (for example).
  4. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies.
    But that can only be done when having 1 voltage output right? In this case I need 6 outputs
    The voltages needed are 50mV, 200mV, 250mV, 300mV, 450mV, 500mV.
  5. tubeguy
    Nov 3, 2012
    1,157
    197
    What is your supply voltage and available current?
    And is the supply voltage well regulated ?
  6. Dritech
    Sep 21, 2011
    756
    5
    The supply voltage will be 12V which will be regulated to 10V using a zener diode. Is the available current of the supply? If so, I will be using a bench top power supply so the current can go up to 5A.
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    You can use this voltage divider.
    And for R7 you can use 180K + 10K or 180K + 51K (precision trim potentiometer). For 3K you can use 3x1K resistor or two 1.5K resistors.
      File size:
      11.2 KB
      31
    Dritech likes this.
  8. #12
    Nov 30, 2010
    16,665
    7,310
    I did it with the 1 ma theory.
    Dritech likes this.
  9. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply :) Can you please tell me how the values were determined? Is the value of R1 assumed?
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes you can assume R1 value and then use Ohm's law to find the current
    I = 50mV/1K = 50uA And next use Ohms low and find the remaining resistors.
    R2 = (200mV - 50mV)/50uA = 150mV/50uA = 3K and so on.
    Or you can assume current as #12 did. But he made a small error.
    He assume 1mA.
    So from then R1 = 50mV/1mA = 50R;
    R2 = 150; R3 = 50; R4 = 50; R5 = 150; R6 = 50; R7 = (10V - 0.5V)/1mA = 9.5K = 9.1K + potentiometer
    #12 likes this.
  11. tubeguy
    Nov 3, 2012
    1,157
    197
    That's where thinking of the divider as 1000 ohms per volt is very useful.
    Ohms law states that 1volt/1000ohms = 1ma. 1ma is a convenient low current which works well in circuits like this.
    The 1ma current flows through the whole resistor string and each resistor has a voltage across it based on it's resistance.
    So, 1000 ohms = 1 volt(1000mv) drop, 50 ohms = 50mv drop etc,,,
    One thing that can easily trip you up is that you need to calculate the drop individually across each resistor in the stack.
  12. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies Jony130 and tubeguy.
