I am trying to design a circuit for a low liquid level indicator using the LM339 Quad Comparator. I have done alot of searching and can't seem to find the details I need. I need about a 1 Volt hysteresis between switch points but can't find the resistor value or placement for that.I believe it would go between the output and the + input, is that correct? I also will only be using 1 comparator so I guess I need to ground the inputs of the other comparators, right? Also, I will be setting a Ref voltage with a 10 turn pot and I read somewhere that I should use a bypass cap somewhere on the divider. But should it go across the entire pot or one end and the wiper, or what? And what value would I use? By the way, the input sensor is a 90 ohm pot and I need to light an LED if the voltage from it goes below 3.0V and extinguish it if the voltage rises above 4.0V. So my Ref is tied to + input and my monitored voltage will be applied to -. Or should I reverse that and sink the current to the LED? Thank you for any help guys.
