Hello everyone!
Various misfortunes drive me in a state where i need to construct a LM338 voltage regulator.
I attach the schematic drawing. This is a combination of two schematics found on the internet. I also attached these schematics (solar battery charger and variable dc power supply).
What I want is not only to set the output voltage, but also set the current limit of the LM338s' output. This is because i want to use it as a power supply but also as a battery charger for small amperage batteries, like 900mAh @ 3.7V. In this perspective, i need a charging current of 90mA.
So in my schematic i modified the variable dc power supply adding the bc547 transistor (from the solar battery charger), which sets the current limit. When the output current rises the R3 and POT2 parallel combination set the value of the output current that will turn the transistor on, which draws current from LM338 ADJ pin, and so the LM338 turns off.
My question is about the values of R3 and POT2. I choose them close to the R2 and POT1 values. Is this ok?
Is there anything wrong with the schematic?
I also attach a very good LM338 datasheet for Texas Instruments.
Thanks!
Thanks!
