Hello SgtWookie
I am building power supply
i problem face
first
i am building this cct
i problem face
first
Note the addition of R3, R4, and the two relays.
R3 is the same value as R2. If K1 is closed, then R3 and R2 are in parallel. Output from the regulator should then be 2.5 Amperes.
R4 is twice the value of R2. If K2 alone is closed, then R4 and R2 are in parallel, and current output from the regulator is 1.25 Amperes.
If both K1 and K2 are closed, then the three resistors are in parallel, and the output from the regulator is 3.75 Amperes
if K1 closed the output is equal to 2.50AIf K1 is closed, then R3 and R2 are in parallel. Output from the regulator should then be 2.5 Amperes
if K2 closed the output is equal to 1.60A not 1.25AIf K2 alone is closed, then R4 and R2 are in parallel, and current output from the regulator is 1.25 Amperes.
If both K1 and K2 are closed the output is equal to 3.04A not 3.75AIf both K1 and K2 are closed, then the three resistors are in parallel, and the output from the regulator is 3.75 Amperes
