LM337SP voltage regulator. what does the SP mean?
Discussion in 'The Projects Forum' started by Videodrome, Aug 18, 2010.
  1. Videodrome
    Nov 12, 2009
    63
    working on a synth project and the parts bill lists a lm337sp. i ended up using a voltage regulator labeled simply lm337 and i keep on burning out power supplies and think it may be because im not using the exact one listed in the parts list. could someone tell me what SP means and why its significant? thanks folks:)
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. tom66
    May 9, 2009
    2,613
    214
    I would recommend you replace it with the beefier LM337T type regulator anyway; if they keep burning out, you have probably exceeded their limits.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Radio Shack carries this part too.
    Since you don't have a location on your profile we have to guess if you have access to certain sources.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Radio Shack carries the LM317, but I think most RS stores stopped carrying the LM337 20 or more years ago.
    Without knowing anything about your supply or load, I'll suggest that either you do not have a large enough heat sink on the regulator IC, your transformer is putting out too much voltage, or you have too much of a load on the output.
    Post a schematic if you want better help.
  6. marshallf3
    Jul 26, 2010
    2,358
    201
    The letters &/or numerals at the end of a device part # usually indicate an improvement &/or change in the design or packaging, much the same as they did with vacuum tubes.
