LM324 hysteresis
Discussion in 'General Electronics Chat' started by banzai, Oct 26, 2014.
  1. banzai
    Jan 3, 2014
    71
    Hi guys
    Is it possible to make a comparator controller with hysteresis using an LM324 Opamp. If possible i would be very thank full if you guys could share a sample diagram on how to build a such setup.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,551
    515
    Yes you can do it but it wont be extremely fast because the LM324 and similar parts are fairly slow to change their output. Typical slew rate is 0.5v/us so if your output has to change from 0 to 10v it will take at least 20us to do that, and another 20us back down from 10v to 0v. This is also true going from -5v to +5v, and if it has to go from -10v to +10v it will take 40us.
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    To add hysteresis, add a resistor (e.g. 1MΩ) from the output to the non-inverting input.
  5. banzai
    Jan 3, 2014
    71
    I am connecting a MOSFET to the LM324 output with a 10K pull down resistor, wouldn't that effect the R3 ?
    PS
    Switching speed is not a problem as i am building a simple temperature controller.
  6. #12
    Nov 30, 2010
    16,665
    7,310
  7. wmodavis
    Oct 23, 2010
    737
    150
