LM324 Func. Generator testing
Discussion in 'The Projects Forum' started by naitek, Apr 25, 2014.
  1. naitek
    May 31, 2008
    15
    hello everyone. I am building a circuit for the umpteenth time, but dont understand the v+/2 in this circuit. How will i get 1/2 the voltage or is it just stating that 1/2 the voltage will be here. Please see attached
  2. naitek
    May 31, 2008
    15
    Forgot the attachment..
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    The circuit assumes that you will provide V+ (or Vcc) divided by 2 and decoupled for low source impedance. So if the circuit power is +9V, you have to supply +4.5V to the reference pin of the hysteretic comparator that converts the integrator's triangle wave into a square wave.
    If you have a spare LM324 section, you can do this with a 2:1 voltage divider driving a LM324 as a voltage follower. If you don't have a spare section, replace with 51K coming from V+/2 with two 100K resistors, one to V+ and one to GND. Do *not* add a decoupling capacitor to the juction of the three 100K resistors and the + input. Just in case you don't know, this is called a Thevenin equivalent (actually a reverse-Thevenin).
    ak
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Here is the schematic again:
    The point with V+/2 should be on half the powersupply voltage.
    In an other schematic from the same datasheet, you can see two resistors and a capacitor (R2, R3 and C1) to make the V+/2:
    Bertus
  5. naitek
    May 31, 2008
    15
    I am just starting on this, but the ac coupled invert. amp is assuming ac voltage or no?
    if so , then what app would i be using it for since i only want a 9v supply.
    thanks for such quick responses..
    -i
  6. DickCappels
    Aug 21, 2008
    2,752
    665
    Not sure if the OP is aware of this, but in this circuit the opamp needs both a positive and and a negative power supply.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
  8. atferrari
    Jan 6, 2004
    2,663
    783
    Why not the cap AK? I think I've seen a cap used all the time.
    What are the three resistors (10K)?
    Confused here.
  9. DickCappels
    Aug 21, 2008
    2,752
    665
    OOPs! A Rose Rosanadan moment ("Never mind"). I just simultaneously realized that the second stage gets VCC/2 for bias and clearly understood the original question.
    You can use one of Bill's excellent circuits or you can probably do very well by making a voltage divider with a pair of resistors, say 3.3k or so.
  10. AnalogKid
    Aug 1, 2013
    4,679
    1,295
    Because unlike the 2nd schematic in bertus' post, your right opamp is acting as a comparator, not a linear amplifier. The plus input is the trip point for the comparator to change states, and must move "instantly" when it does so to effect the hysteresis effect.
    The original schematic is designed for single-supply operation, as long as Vcc/2 comes from somewhere. I've always wondered why they didn't go with the two 100K resistors as in the AC coupled example.
    There were two typos in my post, both corrected now. I meant to say two 100K resistors (not 1000K), and later it was supposed to be three 100K resistors, the original feedback 100K and the two you add to form Vcc/2.
    ak
  11. atferrari
    Jan 6, 2004
    2,663
    783
    Gracias AK. Crystal clear now.
  12. AnalogKid
    Aug 1, 2013
    4,679
    1,295
    Don't think so. The thevenin equivalent resistance of the divider (in your case 1.65K) directly affects the amount of hysteresis and therefore the amplitude of the triangle wave.
    ak
