lm318p not working??
Discussion in 'Homework Help' started by caoadon, Jul 11, 2014.
  1. caoadon
    Jul 11, 2014
    24
    Hi
    I've built an inverting set up with a lm318p op amp,
    but I can't seem to even get an inverting signal in general?
    I just want to get it working so right now the gain is only 1 (using two resistors of same value)
    Ive posted a picture
  2. ericgibbs
    Jan 29, 2010
    2,600
    394
    hi,
    Please post a diagram of your circuit.
    E
  3. caoadon
    Jul 11, 2014
    24
    oh sorry. Here ya go
  4. caoadon
    Jul 11, 2014
    24
    sorry im new to this
    the supply voltage is +9V
    I connected the V- to GND
  5. shteii01
    Feb 19, 2010
    3,515
    515
    I see ground.
    I don't see power. You have red plug plugged into breadboard red socket. Normally from red socket you would run a wire to the breadboard. But you got nothing running from red socket to the breadboard.
  6. caoadon
    Jul 11, 2014
    24
    There's something there. its just a black wire
  7. ericgibbs
    Jan 29, 2010
    2,600
    394
    hi,
    On some types of project board the power rails [ along the long edges ] are not linked thru at the centre pins.
    So if your gray wire is your scope 0V, it may not be connected!.
    Move your scope 0V lead to near the power input rail.
    E
  8. RichardO
    May 4, 2013
    1,342
    431
    Don't forget to add power supply bypassing. The LM318 is very likely to oscillate without proper bypass.
  9. caoadon
    Jul 11, 2014
    24
    Tried that also. Didnt work! :(
    But thanks though
    Does it have to do with the parameters I have on the function generator?
    1kHz, 100mVpp 50mVos
  10. caoadon
    Jul 11, 2014
    24
    What is power supply bypassing?
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  12. caoadon
    Jul 11, 2014
    24
  13. ericgibbs
    Jan 29, 2010
    2,600
    394
    hi,
    A 100nF near the OPA and a 47uF on the project board power rails.
    E
  14. JoeJester
    Apr 26, 2005
    3,403
    1,227
    I noticed the wire you have connected to pin 3 (Vcc-) is connected to your Vcc+ ... assuming that red wire is Vcc+
    The area around the posts is very unclear. Neaten up your diagram ....
    absf likes this.
  15. absf
    Dec 29, 2010
    1,493
    374
    What program did you use to do the bread board layout?
    This is the strip board version of the same circuit.
