LM317T replacement
Discussion in 'The Projects Forum' started by kaushizcute, Feb 17, 2012.
  1. kaushizcute
    Feb 16, 2012
    24
    I have made a basic adjustable regulator circuit using LM317T which has a resistor connected between Vref and Vout and then a potentiometer.
    As LM317T is TO-220 so the size is big for my purpose.
    Can it be replaced by LM317LZ which is TO-92.
    My input is 12V and required output is 3.6V, 140mA.
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    No. The problem is the large voltage drop of 8.4V.
    The device has to dissipate 1.2W. The TO-92 package cannot dissipate this amount of power and will get very hot.
    kaushizcute likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    How about using a zener diode, and a 2 watt resistor.
