LM317T Is there a minimum voltage inputtoget the required output voltage?
Discussion in 'General Electronics Chat' started by RodneyB, Mar 6, 2016.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    648
    14
    Is there a Voltage drop when making a voltage regulator when using the LM317T.
    I am trying to regulate the voltage onto a small load to 12 Volts. I have a battery with a voltage of 13.8 volts as the supply but the output never can be set at 12 Volts. I an trying to understand why
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    Voltage drop : VI – VO, Input-to-output differential voltage, 3V
    LM317 datasheet -- Please check the page 4.
  3. RodneyB
    Apr 28, 2012
    648
    14
    Thank you
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    For a lower voltage difference, you will have to use a LDO (low drop out) voltage regulator.
    The LD1117 or LM2940 will do the job.
    Bertus
    cmartinez, ScottWang and RodneyB like this.
  5. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    How small of a load and what is the required voltage regulation?
  6. RodneyB
    Apr 28, 2012
    648
    14
    Sorry I don't see where it shows on Page 4 the voltage
    The load is 50mA. I would like to keep the voltage at 12 volts
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    On the fourth page, section 7.3, second line item, Vi - Vo Input-to-output differential voltage, MIN(imum) 3V, MAX(imum) 40V.
    For 12V out you need at least 15V in.
    ScottWang likes this.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    Also, even with an LDO regulator, the 13.8 V source that you mention sounds suspiciously like a fully charged lead acid battery. That voltage will drop as the charge drops, so you will probably drop out the regulator before using very much of the battery charge.
  9. dl324
    Mar 30, 2015
    3,377
    651
    Unnecessary requirements will make for an unnecessarily complex solution. If you're powering from a battery, the voltage will drop; even an LDO regulator will be hard pressed to provide a regulated 12V when the battery voltage is in that vicinity.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    If you really need 12 V from a source that is in the vicinity of 12 V, then you will probably need to use a boost/buck regulator that can handle input voltages both above and below the targeted 12 V output.
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It is also the standard DC power supply voltage for Amateur Radio equipment.
  12. WBahn
    Mar 31, 2012
    18,085
    4,917
    Probably because it was historically provided by a lead acid battery.
    Note that the TS specified that he is using a battery.
  13. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    The typical dropout voltage of the LM2940 is about 0.1 Volt @ 100 mA:
    Bertus
  14. hp1729
    Nov 23, 2015
    2,094
    232
    For 13.8 V in and 12 V out consider just using three rectifiers in series to drop the voltage down.
  15. dl324
    Mar 30, 2015
    3,377
    651
    The OP wanted to supply 12V, which I took to mean precise to at least two decimals, to the load...
    RodneyB likes this.
  16. hp1729
    Nov 23, 2015
    2,094
    232
    Yep, then LDO regulators are the way to go.
    RodneyB likes this.
  17. dl324
    Mar 30, 2015
    3,377
    651
    Unless the OP plans to trim the LDO, it may not give the precision he wants. Datasheet says 11.40-12.60V over the full temperature range. If the circuit will tolerate 5% supply variation, a couple diodes could be sufficient (when the battery is fully charged).
    RodneyB likes this.
  18. hp1729
    Nov 23, 2015
    2,094
    232
    Of course. Always a given.
    RodneyB likes this.
