AlphaDesign888
- Joined Jul 27, 2014
- 193
Yeah I think Mark set me straight by saying that the supply wpuld have to be able to 'SINK' current.No. The two power supplies will behave exactly like the two LM317s.
Have you looked at the standard LM317 configuration? There two resistors in series across the output. The junction of these is fed back to an input of an internal differential opamp. The other input of the of opamp is an internal reference. The output of the opamp drives the internal pass transistor. If the output voltage is higher than the desired voltage, the voltage at the resistors' junction will be higher than the reference voltage and the opamp will reduce the drive to the pass transistor. This will continue until the voltage at the output matches the sensed voltage with the reference voltage. Lab supplies work the same. Since the 5v supply holds the top of the 4V regulator's series resistors at 5V, the 4V regulator reduces its pass transistor drive to cutoff in a futile attempt to sense 4V.
Ken
Thanks for your response too Ken.
