If you are using the 3 Watt powerleds, keep the cooling of the leds in mind.
Without cooling the leds the lifetime will be very short.
They are mounted on an aluminium frame that can be mounted on a cooling frame.
When using a LM317 on 12 Volts for 1 led of 3.8 Volts (estimated for a white led),
the LM317 will dissipate about (12 - 3.8 - 1.2)*0.7 = 4.9 Watts, so this needs cooling also.
Greetings,
Bertus
Greetings,
Bertus
