Yeah it is very hard to get to them now. Sorry. There are actually 5 red leds wired to each lm317
Depending on the forward voltage of the LEDs, five LEDs is pushing the limit of operation with the voltage range you are applying.Yeah it is very hard to get to them now. Sorry. There are actually 5 red leds wired to each lm317
That is cutting it a bit close.the forward voltage is 1.8 per led
This thread is about 9 months old. It looks to me like spam - an opportunity to advertise that damned strange invitation letter web site in his signature line.You can use this calculator to vary the value of the program resistor (R1) and output set resistor (R2) and calculate the output voltage for the LM317 / LM338 / LM350 family of three terminal adjustable regulators. This calculator will work for most voltage regulators with a reference voltage (VREF) of 1.25. Typically, the program resistor (R1) is 240 ohms for the LM117, LM317, LM138 and LM150. For the LM338 and LM350, 120 ohms is typically used. However, other values such as 150 or 220 ohms can also be used. Refer to the adjustable regulator datasheets below for more information.
If the control signal going high is supposed to turn on the LEDs, it won't. It will turn them off. If it is active low, then you're OK, except the transistor source and drain are swapped.Corrections!!!
I made a few errors in my last post.
Here is the revised circuit of what i was trying to say.
No way!!Or just replace your burned out LEDs regularly, .
Thread starter | Similar threads | Forum | Replies | Date |
J | LM317 current injector/boosting circuit | Analog & Mixed-Signal Design | 28 | |
K | Mounting LM317 TO-3 case | Power Electronics | 13 | |
L | LM317 no reference voltage | Power Electronics | 20 | |
LM317 Adjustable Voltage Regulator project | General Electronics Chat | 17 | ||
K | Lm317 high current voltage regulator circuit | General Electronics Chat | 28 |
by Duane Benson
by Aaron Carman
by Jeff Child
by Duane Benson
