LM317 voltage regulator circuit
Discussion in 'Homework Help' started by notoriusjt2, Dec 15, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
    allright. I pulled up the LM317 spec sheet and found the following
    so....here is the work I have based on this equation
    I am wayyyyy off base here. what am I doing wrong?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The adjustment pin current is typically a max of ~5uA for the LM317. You appear to have Iadj = 0.01A - which is way off.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    In R2 of your schematic (your diagram and the application notes have reversed designations) you have 100Ω. Since the method the LM317 uses is to maintain 1.25V between the output pin and adjust you should be able to figure current. The current through R2 is the same as through R1. From there it is gravy.
  4. Jony130
    Feb 17, 2009
    3,991
    1,116
    Iadj is 50uA typical, and 100uA=0.0001A max.
    But this circuit can be treat as a voltage divider.
    Since R2 = 100Ω and voltage across R2 is equal 1.25V we have
    IR1 = 1.25V/100Ω = 12.5mA
    And the current that is flow through R1 is equal
    IR2 = Iadj + IR1 = 12.6mA
    And we want Vo = 15V----> VR1 = 15V - 1.25V = 13.75V
    R1 = 13.75V/12.6mA = 1.09126984KΩ
    R1=R2*\frac{Vout-1.25V }{1.25V+I_{ADJ}*R2}
    Or
    R1=R2*(\frac{Vout }{1.25V}-1)
  5. Kermit2
    Feb 5, 2010
    3,851
    966
    The position of R2 and R1 are different in your problem and in the example you posted. Go back a redo the math and notice carefully how the fraction made by the resistor values is arranged in the example and how the Resistors in the problem are the reverse.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Agreed - I misread the data sheet. Looked at the adjustment pin current change row rather than the actual value. I can only put it down to deteriorating vision.
    Apologies for the misinformation.
  7. notoriusjt2
    Feb 4, 2010
    209
    what is the variable "Uwy" referring to?
  8. Jony130
    Feb 17, 2009
    3,991
    1,116
    Well in my country "Uwy" means exactly the same as Vout in english.
    And sorry for confusion
  9. notoriusjt2
    Feb 4, 2010
    209
    no worries... what country is that?
  10. Jony130
    Feb 17, 2009
    3,991
    1,116
  11. notoriusjt2
    Feb 4, 2010
    209
    thats a great explanation.
    I = 0.0125A
    R = 13.75/0.0125 = 1100
    which is basically the same answer that was derived by Jony130
    however, this answer was listed as wrong
    what are we doing wrong here?
  12. notoriusjt2
    Feb 4, 2010
    209
    what is the dropout voltage? could that have anything to do with it?
  13. Jony130
    Feb 17, 2009
    3,991
    1,116
    Maybe answer is wrong
    As for the dropout voltage some times called headroom voltage read this
    http://en.wikipedia.org/wiki/Dropout_voltage
  14. notoriusjt2
    Feb 4, 2010
    209
    per wikipedia
    "In electronics, the dropout voltage of a voltage regulator is the smallest possible difference between the input voltage and output voltage to remain inside the regulator's intended operating range."
    so if I understand correctly the dropout voltage has no effect on what the output voltage will be.
  15. notoriusjt2
    Feb 4, 2010
    209
    I am to the point now where I am mindlessly staring at this problem... ugh
  16. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  17. notoriusjt2
    Feb 4, 2010
    209
    but my schematic looks different from the one that is in that PDF
    for example
    what values should I use for Rwp and Rwn?
  18. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Rwn and Rpn are the resistances of the wires from the regulator to the load.
    These will be dependend on the used wire, but can be dismissed when using small loads, as the values are mosttimes very small.
    Bertus
  19. notoriusjt2
    Feb 4, 2010
    209
    allright so in the equation they are subtracting (IL*Rwp), which in reality is the voltage drop of the wire. since this loss is negligible we will disregard it.
    R2 should be -88
    also incorrect
  20. Jony130
    Feb 17, 2009
    3,991
    1,116
    Check your math.
    15 = 1.25 * ( 100 + R2)/100
    1500 = 1.25*(100 + R2)
    1500 = 125 + 1.25R2
    R2 = 1375/1.25 = 1100
