LM317 Question
Discussion in 'General Electronics Chat' started by Dr.killjoy, Jul 12, 2013.
  1. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    What is the purpose of the Tantalum capacitors in a lm317 circuit and does it matter what these values are ??????
  2. Shagas
    May 13, 2013
    802
    74
    which lm317 circuit?
    Dr.killjoy likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Have a look at this schematic that Bill_Marsden has drawn:
    The small capacitors at the input and output are there to prevent the LM317 from oscillating.
    Bertus
  4. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Does the values matter or can I use any cap I have laying around ???
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    In the standard configuration, there are values between 0.1 and 1 μF used at the output.
    At the input there is always a 0.1 μF capacitor.
    Bertus
  6. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    What the signification of using that certain value???
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    The explanation can get highly technical - and a bit dry unless you're a mathematician, you can easily get lost in the theoretical maze of filters and poles!
    OTOH; most manufacturers publish reasonably clear application notes that explain the placement of decoupling capacitors, generally; the o.1uF caps should be as close to the regulator as possible - some regulator types have cautions with using multilayer ceramic chip capacitors - so *DO* read the appnote.
  8. LvW
    Jun 13, 2013
    674
    100
    For my opinion, the only purpose of C3 is to ensure (or improve) stability properties of the whole circuit. In this regard, the internal loss resistance of the capacitor is also important (the quality of the cap should be not "too good")
    Don`t forget, there is a feedback loop via R1 and R2.
  9. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Thank you everyone for the help
    Personalian field I want to thank you for your input and it really help out alot .....
    http://www.youtube.com/watch?v=UW_XFGGTh0I
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    If using a pot like in the circuit in post #3, it should have a capacitor from the ADJ pin to ground too.
    PackratKing likes this.
  11. ian field
    Oct 27, 2012
    4,447
    791
    Another point worth checking on the appnote - I've a dim & distant memory something like a cap on the Adj pin compromises ripple rejection.
    But I haven't used 3-terminal regulators for quite some time - like I said, *DO* read the appnote.
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    No it's the opposite. Having a cap from Vadj to Gnd fixes the voltage at Vadj, and the result is higher closed loop Voltage gain (Vripple:1.25v), so it gives improvements in ripple rejection compared to the normal voltage gain from the resistor divider (Vripple:Vout).
    The main reason for the cap on the adjust pin is that pot's are not perfect, they crackle and get high resistance when being turned. A cap on the ADJ pin means this HF noise from the pot won't be amplified by the LM317 at a high power level.
    In a worst case, if the pot wiper goes open circuit (even for a very short time) the voltage between Vout and Vadj drops to zero, and the LM317 turns on full and presents the full PSU (Vin) voltage at the output!
  13. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Another Question
    I plan to use a 12v wallwart and want to use the LM317 to 1.5v or lower but I know the LM317 needs a heat sink but I am not sure what size to use ??
    Here my math but not sure if it's right
    12v-1v*.6ma = 6.6 watts of heat dissipation
    But would one of these work
    OR
  14. WBahn
    Mar 31, 2012
    18,085
    4,917
    Your math is not right, but at least by including the units this is catchable.
    First, I'm going to assume you meant:
    (12v-1v)*.6ma
    If so, the result is 6.6mW, not 6.6W.
    If, instead, you meant 0.6A and not 0.6mA, then your result is correct.
    What is the thermal conductance, case-to-ambient, for that heat sink?
  15. BobTPH
    Jun 5, 2013
    806
    121
    If you are tying to get 1V out of an LM317, good luck. The min is 1.2V.
    Bob
